October 18, 2004, 04:27 |
Very simple combustion problem.
Hi, I am having serious problems with what seems to be a very straight forward problem.
I have 2 inlets and an outlet. Very simple 2-D axisymmetric model. One inlet I have Oxygen and the other Hydrogen. O2/H2 ratio is about 3:1 I am using the Hydrogen/Air mixture template. I have a good model with very good residuals under non-reacting conditions. I have a well adapted mesh. Problem: I apply a temperature patch to a region near the inlet. Solution runs and the temperature increases over 3000K as expected. After about 5000 or so iterations, the flowfield is cold and there is no longer a flame. I cant work it out and would be extremely grateful of any assistance. Jouch |
October 21, 2004, 02:57 |
Re: Very simple combustion problem.
what combustion model are you using ...
October 21, 2004, 21:40 |
Hi, I first tried the non-premixed with a pdf file. This was not succesful. The chamber pressure would not increase despite the fact I was constantly increasing the mass flux of propellants!? The only way I could increase the internal (chamber) pressure was to increase the pressure outlet (incrementally to avoid divergence) which is a very lengthy and seemingly incorrect way to do things.
Also crazy results using this approach....i.e. 120K Oxygen at 5.4MPa normally has a density around 1000kg/m³ but Fluent is telling me 20kg/m³...! So,now I am trying simply with the species transport model but so far no good. Thanks for any feedback. Jouch |
October 21, 2004, 22:12 |
i have a pretty good experience with combustion modeling, and have done lot of analysis with fluent so if you can send me a mail decribing 1. boundary conditions (and other required conditions) 2. fuel you plan to burn etc. leave the geomtery details, i shall be writing an email to you describing step by step what shall you do to get that done, i might write this on this saturday or sunday as i can't send emails from office (some secrecy fundas), my email is zxaar@yahoo.com
October 21, 2004, 22:28 |
Hi again,
That would be great if you could make a brief step-by-step procedure as to what I must do... That way I can also explain further as to exactly what I want to do. Implement a real gas UDRGM for O2 at supercritical conditions. I have had quite a bit of experience with the Fluent basics and I have read quite a lot in the manuals but to no avail. I would be extremely appreciative of your assistance. I will write now. Regards, Jouch |
combustion chamber problem | mcnair | ANSYS Meshing & Geometry | 0 | March 16, 2011 12:41 |
Combustion problem in STAR CD... help me, please! | mrkokoko | STAR-CD | 1 | September 14, 2009 17:00 |
Combustion problem | rupal | CFX | 0 | April 21, 2008 05:29 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
? Simple CFD problem | Davy | Main CFD Forum | 0 | August 21, 1998 06:19 |
