turbo file, need help
Old   October 20, 2004, 03:26
Default turbo file, need help
chandra manik
Dear friend, i would like to ask some help from tou. I created turbo file based on step in user guide and i succeded to make one but when i make the new one like this (see below), gambit failed to identify (making line or etc), some error messages are : blade must be more than 1 and etc. Any one can help me to guide and fix this problem?.
Thanks for your antentions
sincerly
chandra manik / FILE VERSION (THIS FILE AUTHORIZED BY CHANDRA MNK FOR BPPT TURBINE 7 MW) 1 3 1 / ROTATIONAL AXIS : SUMBU Y (Y-AXIS) 1 / COORDINATE SYSTEM TYPE : CARTESIAN 0 / / HUB DATA : 1 EDGE DEFINED BY 2 POINTS 1 2 5 -18.651 501 5 18.651 501 / / TIP-CLEARANCE DATA: 1 EDGE DEFINED BY 2 POINTS 1 2 5 -18.651 515 5 18.651 515 / / BLADE DATA: 1 BLADES, 2 PROFILES/BLADE, 2 EDGES/SIDE 1 / / BLADE 1 2 2 / PROFILE EDGE CONTINUITY 2 1 0 / / BLADE 1, PROFILE 1, PRESSURE SIDE 10 0.0 13.4982 501 3.951601325 14.78048716 501 1.424590679 14.1033767 501 -0.94645 12.99774227 501 -3.08947784 11.49717802 501 -4.939378025 9.64727784 501 -6.439942273 7.50425 501 -7.545576699 5.133209321 501 -8.222687161 2.606198675 501 -8.4507 0.0 501 8 -8.4507 0 501 -8.222687161 -2.606198675 501 -7.545576699 -5.133209321 501 -6.439942273 -7.50425 501 -4.939378025 -9.64727784 501 -3.08947784 -11.49717802 501 -0.94645 -12.99774227 501 0.0 -13.4982 501 / BLADE 1, PROFILE 1, SUCTION SIDE 15 0.0 -13.4982 501 -0.2 -13.4982 501 -0.4 -13.4982 501 -0.6 -13.4982 501 -0.8 -13.4982 501 -1 -13.4982 501 -1.1464 -13.4982 501 -1.1464 -13.4982 501 -12.3096 -4.8324 501 -12.93935155 -4.310532081 501 -13.63299171 -3.61696588 501 -14.19564456 -2.8135 501 -14.61021419 -1.924547346 501 -14.86410411 -0.977118296 501 -14.9496 0.0 501 15 0.0 13.4982 501 -0.2 13.4982 501 -0.4 13.4982 501 -0.6 13.4982 501 -0.8 13.4982 501 -1 13.4982 501 -1.1464 13.4982 501 -1.1464 13.4982 501 -12.3096 4.8324 501 -12.93935155 4.310532081 501 -13.63299171 3.61696588 501 -14.19564456 2.8135 501 -14.61021419 1.924547346 501 -14.86410411 0.977118296 501 -14.9496 0.0 501 / BLADE 1, PROFILE 2, PRESSURE SIDE 10 0.0 13.4982 504 3.951601325 14.78048716 504 1.424590679 14.1033767 504 -0.94645 12.99774227 504 -3.08947784 11.49717802 504 -4.939378025 9.64727784 504 -6.439942273 7.50425 504 -7.545576699 5.133209321 504 -8.222687161 2.606198675 504 -8.4507 0.0 504 8 -8.4507 0.0 504 -8.222687161 -2.606198675 504 -7.545576699 -5.133209321 504 -6.439942273 -7.50425 504 -4.939378025 -9.64727784 504 -3.08947784 -11.49717802 504 -0.94645 -12.99774227 504 0.0 -13.4982 504 / BLADE 1, PROFILE 2, SUCTION SIDE 15 0.0 -13.4982 540 -0.2 -13.4982 540 -0.4 -13.4982 540 -0.6 -13.4982 540 -0.8 -13.4982 540 -1 -13.4982 540 -1.1464 -13.4982 540 -1.1464 -13.4982 540 -12.3096 -4.8324 540 -12.93935155 -4.310532081 540 -13.63299171 -3.61696588 540 -14.19564456 -2.8135 540 -14.61021419 -1.924547346 540 -14.86410411 -0.977118296 540 -14.9496 0 540 15 0.0 13.4982 540 -0.2 13.4982 540 -0.4 13.4982 540 -0.6 13.4982 540 -0.8 13.4982 540 -1 13.4982 540 -1.1464 13.4982 540 -1.1464 13.4982 540 -12.3096 4.8324 540 -12.93935155 4.310532081 540 -13.63299171 3.61696588 540 -14.19564456 2.8135 540 -14.61021419 1.924547346 540 -14.86410411 0.977118296 540 -14.9496 0.0 540
Old   October 21, 2004, 07:38
Default Re: turbo file, need help
SAM
hi , come online on yahoo
my net was down
bye
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
