dynamic pressure error
Old   November 15, 2004, 11:17
Default dynamic pressure error
Benj
When I want to plot my dynamic pressure field I got this error message:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Can somebody tell me what to do? Moreover the static pressure field I got in this same case is false: is there any connection.
Thanks
Benjamin
Old   November 15, 2004, 11:27
Default Re: dynamic pressure error
SAM
1. did u use the adpat grid option in fluent with hanging mode
regards
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
