Rotational speed
Old   December 1, 2004, 06:30
Default Rotational speed
Ruben
Hi there,
I am studying a wells-turbine. This turbine is running at high rpm. I know the inlet and outlet boundary conditions. The problem is that I dont know how to give a rotational speed to the turbine. If I only set inlet and outlet boundary conditions the results are like the turbine was stopped.
What to do?
Thanks
Old   December 1, 2004, 23:38
Default Re: Rotational speed
guru
Checkout about MRF...
-guru.
Old   December 3, 2004, 08:38
Hongfw
You must set the fluid zone as the rotation zone.
Train Speed yeo FLUENT 5 February 14, 2012 08:38
Can sliding mesh use varying rotational speed? Shengyi FLUENT 1 February 14, 2009 16:01
rotational speed to wall zone cosimo FLUENT 0 August 23, 2006 10:07
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 20:38
udf in MRF to update the rotational speed Jam FLUENT 0 August 21, 2005 12:50
