UDS gradient
Old   December 14, 2004, 10:24
Default UDS gradient
Giordano Bruno
Hi to all fluent users,
I'm working with FLUENT 6.020 and I've to define two UDSs, but when I try to use the function C_UDSI_G(c,t, i)I obtain, as usual..., an error message.
Any suggestion will be appreciated!!!
Thanks in advance.
Giordano Bruno
Old   December 14, 2004, 11:34
Default Re: UDS gradient
S. Hollman
If you are referring to a runtime error when using your adjust function that contains the C_UDSI_G(c,t) command, you have to run one iteration with the hook function turned off.
Why? I do not know.
Old   December 15, 2004, 03:25
Giordano Bruno
Thank you very much!!!
I'm going to try your suggestion...
Giordano Bruno
Old   December 17, 2004, 09:46
Joey
Doctor Caojing told me that before iteration no memory for the gradient is allocated, so before you call the gradient of any uds or other variable, you need to run one iteration.
Old   December 17, 2004, 16:32
Giordano Bruno
Thank you very much for your useful responses.
Giordano Bruno
Gradient of UDS gemini Fluent UDF and Scheme Programming 2 December 24, 2013 00:24
How to compute UDS fourth order gradient Emma66 FLUENT 1 April 27, 2010 05:44
reconstruction gradient of a UDS gemini Fluent UDF and Scheme Programming 0 June 7, 2009 16:03
Gradient UDS tom FLUENT 1 April 28, 2006 03:46
Gradient of a UDS Ilkay FLUENT 0 March 8, 2000 13:42
