January 18, 2005, 12:11 |
UDF velocity profile problem
When setting a velocity profile that contains zero values on an inlet plane I run into problems with tke and epsilion profiles on that same plane. The tke and epsilon profiles are also set using a UDF, however for the regions where the velocity is set to zero, the values of tke and epsilon do not agree with the set values in the UDF. "Banding" occurs where I get multiple values along the inlet plane. Since I set these profiles with a UDF on the whole plane, I do not understand why the values should change. Have you seen this before? Is there a fix? Thanks for your time! Steve |
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
UDF for 3d inlet parabolic velocity profile ? | shahzeb irfan | Fluent UDF and Scheme Programming | 10 | March 28, 2016 15:00 |
UDF velocity and temperature | Raj | FLUENT | 3 | February 1, 2009 18:29 |
UDF velocity profile at nodes | Emad | FLUENT | 2 | January 29, 2009 06:35 |
UDF for Velocity profile in 3D rectancular duct | Emad | FLUENT | 0 | January 21, 2009 03:11 |
