Hi all, Ive done a search on this but cant find much to help so thought I would post the question.
I am tring to model a computer case, Its includes a CPU fan, case fan, and outlet. I ran this simple analysis and it went fine. However, i am now modeling the CPU and heat sink with heat transfer. The model is as follows, a small block which has been subtracted from the fluid domain (it is attach to the wall of the fluid domain (the casing)) so that it gives me a small face to apply the CPU temperature. attached to this small surface is the heat sink (is is subtracted from the fluid domain too). Is this the correct way of modelling it, or does the heat sink need to be its own volume?? what boundery conditions need to be applied?? thanks |
explain your problem clearly. I am not getting any thing from your explanation. I am working in the same area. If you want more information you can mail to me.
VenuGopal. S |
Help needed in using wall BC for heat transfer analysis of heat exchanger tubes | hassaan | FLUENT | 2 | June 25, 2013 07:05 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
