Fluid not heating up
Old   February 21, 2005, 05:19
Default Fluid not heating up
ocy
Hi all,
I am Modeling a 2D chimney.
I have a solid heat source(0.4m x 2m) at the base of my chimney(1m x 50m). The rest of the chimney is consist of air(fluid zone)
I set energy source term for my solid with a heat generation rate of 1000w/m^3.
However, When i iterate, only the solid zone heats up. The fluid zone remains at ambient temp.
Can anyone help? Thanks
Old   February 21, 2005, 22:00
Default Re: Fluid not heating up
Venugopal
hi, 1000w is not sufficient to heat the air. You can check in another way also. Give a low thermal conductivity to the air or you can increase the heat generation rate in heat source. If you are finding any temp difference in the air, then you approach is correct, otherwise you are not going in correct path.
Venu Gopal. S
Old   February 22, 2005, 04:16
ocy
Hi Venu Gopal,
Thanks for your help. I increased my heat source to 1e+10 w/m^3. The fluid gets heated up.
When i removed the insulation at the wall, the temp at the wall drops as expected. However, the temp of the fluid at the interior is not affected much. The temp is still v high.
How could this be so??
Pls help. Thanks in advance.
Regards, ocy
Old   February 22, 2005, 20:46
Venugopal
The temp. of the fluid should increase, because the walls are very high, all fluid temperature might be at uniform. Tell me your problem clearly.
Venu Gopal
Old   February 24, 2005, 03:43
ocy
Hi Venugopal,
When i remove the insulation of the wall, The temp of the flow inside the chimney remains very high. Only a small region near the wall show a decrease in temp.
Is this expected? Or have i done something wrong?
Thks
uniform heating of fluid region santoo_cfd OpenFOAM Running, Solving & CFD 15 March 18, 2016 03:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
