February 21, 2005, 11:54 |
error reading journal files
I am using a journal file to run fluent, it always stops afer 10 iterations and producing the following error: Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed. > Halting due to end of file on input. but this doesn't happen in GUI window. Any one knows the possible reason? Thanks wenbin |
February 21, 2005, 21:56 |
Re: error reading journal files
Hi, I am also running fluent with journal files. Can you send me that file, because after reading your journal file I can say what is the mistake.
Venu Gopal |
February 22, 2005, 04:43 |
Hi, this is my journal file, the error happens on the second line, I am really puzzled as it works fine within the GUI?
file confirm-overwrite no file read-case-data nacelle solve monitors residual convergence-criteria 0.000003 0.000001 0.000001 0.000001 0.000001 solve monitors residual print? yes solve monitors residual plot? yes solve set under-relaxation pressure 0.2 solve set under-relaxation mom 0.2 solve set under-relaxation temperature 0.2 !\rm nacelle.cas nacelle.dat solve iterate 6000 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
CFX-Build journal files | KG | CFX | 2 | November 18, 2002 07:03 |
