Problem with Eccentric pipe annulus..Pls Help me |
Hello, I am using Fluent to study the flow of Non-Newtonian Fluid through pipe annulus.To verify my results (pressure drop over length of pipe)with analytical, at present I am using Fluid of density 800 kg/m^3 and Viscosity 1 kg/m-s. I got the results matching with analytical solution for 2D geometry in Gambit for concentric annulus only. But when I make the annulus eccentric the pressure drop is more than the concentric annulus(outer pipe is 2m in diameter50m long; inner pipe is 1 m in diameter and 50 m long; I am using offset of 0.1,0.2,0.3..from center). (In Gambit,first I am creating vertices and then edges--joining edges to creat rectangular face--then subtracting inner rectangle from outer retaining innner rectangle to get the annulus--meshing edges,faces--and specifying boundary conditions as VELOCITY INLET and PRESSURE OUTLET). I have tried to refine the mesh but couldn't get the answer. I also tried in 3D , but in 3D I couldn't even get the results matching with analytical for concentric annulus. I would appreciate it greatly if you can help me with this. Thank you very much for your time
Best Wishes, Parag |
pls send the information regarding how to extract the dynamic pressure in fluent. and how to write on excel file.then how to the regession.
monitors/surface/dynamic pressure on what you want/ after you have to open it in excel. easy
cip |
[ANSYS Meshing] Problem with O-grid in drill pipe | bahadir | ANSYS Meshing & Geometry | 8 | May 6, 2011 11:51 |
convergence problem in a long pipe | feizaghaee | CFX | 7 | February 16, 2010 08:05 |
Flow through a pipe problem | Mark Wisom | Main CFD Forum | 4 | July 25, 2002 13:20 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
pls explian me how to simulate 2d-labyrinth seal problem using fluent4.23 | murali mohan | Main CFD Forum | 0 | October 26, 1999 01:40 |
