C_WALL_DIST Segmentation Violation error
Old   March 20, 2005, 09:42
Default C_WALL_DIST Segmentation Violation error
ap
I need to use the C_WALL_DIST macro to implement a different turbulence model in my UDF, but each time I try to use that macro I get a segmentation violation error.
The FLUENT UDF manual is lacking, as always! There is no documentation on this macro.
Does someone knows what could be the matter?
Best regards, ap
Old   March 20, 2005, 12:32
Default Re: C_WALL_DIST Segmentation Violation error
ap
I found this works only if I enable the "Enhanced wall treatment", which seems strange, because the I can always plot the Cell-wall distance using the Grid->Cell-Wall distance option.
Is this ok, or is it a bug?
Regards, ap
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
