Combution problem
Old   March 23, 2005, 08:05
Default Combution problem
mneo
How can I simulate CO combution process in chamber which walls are water cooled? How can I define mixture of gases and reactions insie chamber and pure water stream inside walls? please help regards
Old   March 23, 2005, 22:37
Default Re: Combution problem
Kumar Swamy
For CO combustion which is a gaseous combustion, you can use approach given in tutorial-12 for fluent's tutorial, if your problem is pre-mixed and/or gaseous/homogeneous combustion, based on finite chemical kinetic theory.
for modeling water cooled walls, you can use lumped approach for simplification of the problem, as the main focus is CO combustion.
regards kumar
Old   March 24, 2005, 07:10
mneo
Thanks a lot! I use directions included in tut.file-12. If I simulated only combustion problem, I would neglect the water cooled walls. My water cooled off-gas duct is 70m long and the outlet temperature is one of the most important unknown I wanna get. I tried to define heat flux for duct walls with negative sign but temperatures of fumes in the vicinity of wall reached T=-3000K !!!
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
