Help needed regarding Dynamic Mesh Model
Old   March 23, 2005, 12:07
Default Help needed regarding Dynamic Mesh Model
Saad
I'm using FLUENT for a part of my MS thesis problem. I need some help regarding the dynamic mesh model. I have a deforming domain. The deformation is defined by means of the motion of one of the boundary of the domain. The problem is that I don't have a functional form for the boundary motion. Instead the shape of the boundary is described at every time step by a set of ordered pair (x_i,y_i) where i is the node number. This data is obtained from a program writen in MATLAB. Is it possible to describe boundary motion by means of a set of data at each time step in the dynamic mesh model.
Old   March 23, 2005, 22:19
Default Re: Help needed regarding Dynamic Mesh Model
teacher
hi,
Yes, you can do this. You need to write an UDF to describe you motion. If you find time, go through UDF manual and every thing is written very precisely. You did not mention any thing about your university. Hope this might answer your question.
Thanks
Old   March 23, 2005, 23:58
Saad
Thanks for your help. I appreciate it. I'm a student at the King Fahd University of Petroleum & Minerals, Saudi Arabia.
Sincerely,
Saad
Old   March 29, 2005, 10:19
Amadou Sowe
I think you can also do it using boundary profiles.
Old   April 9, 2005, 02:09
Anatoly
Greetings! I am engaged in a few(a little,little bit) use of dynamic grids. Typical problems(tasks) which I solve – the vertical free and compelled fluctuations vertically focused î the cylinder on section of phases water - air. There are some problems in the decision of these problems(tasks). With a part of these problems I have already understood. Probably it will interest you. The best regards!
problem of dynamic mesh for a piston model pipin Fluent UDF and Scheme Programming 2 August 2, 2010 14:35
about dynamic mesh model lingo FLUENT 0 August 2, 2004 21:43
