Easy GAMBIT question
Old   March 30, 2005, 20:23
Default Easy GAMBIT question
noName
Hi I have a beginner-level questions about GAMBIT:
When creating two volumes adjacent to each other, do they need to share a common face? I see that I can make two (or more) faces at the same location, which can be used to construct different volumes. I would not like to boolean add these volumes together because that makes me lose grid information on some of the edges. Which way should I go to make sure that the face is a fluid-fluid interface -- one face or two?
Old   March 31, 2005, 02:09
Default Re: Easy GAMBIT question
mateus
Hi!
If two volumes share one common face you can forget about it...fluent(gambit) automatically sets it as a fluid-fluid interface. If you have 2 faces (each designated to one volume) in the same position (for example if you create 2 cubes on besides another) fluent(gambit) will treat it as an outside wall...that means that yoou have to specify them (both!) as intrefaces...
hope it helps MATEUS
Gambit question HP FLUENT 8 March 4, 2005 08:32
Question on Gambit. Sham FLUENT 2 February 15, 2005 20:07
Easy question Confused Main CFD Forum 4 May 22, 2004 02:14
GAMBIT QUESTION stephen davis FLUENT 3 March 11, 2002 10:52
GAMBIT Question Eric FLUENT 2 February 28, 2002 22:24
