convergence metrics
Old   April 3, 2005, 00:19
Default convergence metrics
swarup
I am facing a peculiar problem. i start my cold flow simulation with a segregated steady state solver and then switch to a coupled solver for mixing-reaction simulation. due to this shift and the fact that i am using steady-unsteady route, residual definitions change and all residuals go northwards. i have been monitoring all primitive variables and find that they are under control and varying slowly. my intermediate results are also physically meaningful. to advance calculation in time i have STOPPED MONITORING ALL residuals and allowing calculation to advance to next time step with a pre-specified number of iterations per time step. is it OK to turn off all residual monitors and judge convergence based solelu upon variation of primitive variables? thanx for any advice/suggestion in this matter.
Swarup.
Old   April 3, 2005, 00:50
Default Re: convergence metrics
pUl|
That's what I do for my case, bubbly pipe upflows. I do not trust the residuals alone. I monitor relevant flow quantities and wait for them to level off. But I cannot be sure whether this will apply to your case as well.
Old   April 3, 2005, 01:25
swarup
i am treating a case which is unsteady for entire flow time, i.e. it never reaches a steady state during the flow time. so, i don't think i will be able to see "levelling off" of any flow quantities in my case. the problem is i do not have good experimental data to compare predictions and have to rely solely upon understanding of physical phenomena inside the reactor to verify results. swarup.
Old   April 3, 2005, 01:30
pUl|
I spoke too soon without reading your steady-unsteady shifting. Sorry.
Old   April 3, 2005, 01:35
pUl|
Oh, and if you're not aware, here is a route to aca-support. They may be able to help. (Monday to Thursday, 9:00 PM to 10:30 PM, EST)
http://im.chatanywhere.net/chatanywhere.php?u=1603
Hope that helps...
Best Regards, Srinath Madhavan
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
