Help! Total heat transfer rate doesn´t sum to zero
Old   April 6, 2005, 02:55
Default Help! Total heat transfer rate doesn´t sum to zero
Thomas
i´m modelling a natural convection and radiation (do) problem. After 6000 Iterations (steady case) the residuals have flatten down (continuity =1e-2, the velocity, k, epsilon are at about 1e-4, energy and discrete ordinate 1e-6). But the sum of the "total heat transfer rate" for all boundaries is far away from zero. It is at about 5000W. My inlets and outlets have a total heat transfer rate between 4000 and 6000W. Is this a indicator that my solution isn´t total converged? After 17000 iterations it´s still the same problem. After that I built up a small problem to investigate this behavior. The result: The total heatflux sum to zero.
I would be pleased for any kind of help! Thank you!
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
total pressure influence on heat transfer fab Main CFD Forum 8 May 19, 2005 09:24
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Turbulent wall heat transfer rate? Tom Main CFD Forum 1 March 1, 2001 05:51
