April 12, 2005, 08:39 |
Construct a three-sided surface in Gambit
I used to construct in Gambit the 3D four-sided face using the journal file
face create vertices "vertex.1" ..... ... "vertex.N" rowdimension Ndim This generate my surface patches correctly. Now I have some degenerate faces (e.g, three sided faces) but defined as a four-sided faces with coincident points (says the first row). In this case gambit don't construct the face and prompts that some points are coincident. The question is : How to construct the three-sided faces using this kind of definition ? Thanks a lot |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Construct a three-sided surface in Gambit | User | FLUENT | 0 | March 26, 2005 04:49 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
Thin Surface in Gambit | cfd guy | FLUENT | 2 | August 16, 2001 12:47 |
