How to active the turbulent models
Old   May 14, 2005, 09:52
Default How to active the turbulent models
w0er
How could I active the turbulent models that didn't exist in the list.Just like des model,les model.
Old   May 14, 2005, 10:42
Default Re: How to active the turbulent models
pUl|
CHeck the manual, You must be in 3D I think, if you want to activate LES.
Old   May 16, 2005, 09:57
w0er
I don't think so,I have herad somebody have had defined 2D les....
Old   May 16, 2005, 18:15
pUl|
An excerpt from http://www.fluentusers.com/fluent61/...ug/node459.htm
!! The Large Eddy Simulation model is available only for 3D cases.
Old   May 16, 2005, 22:35
zxaar
to activate les model in 2d
(rpsetvar 'les-2d? #t)
Old   May 16, 2005, 22:39
zxaar
yes after this yopu have to go and check in viscous model panel to activate it
Old   May 17, 2005, 00:22
pUl|
interesting.
Old   May 17, 2005, 02:28
zxaar
actually lot of things are not given in fluent manuals, or they are not given at the place they should be given,
i found this out while doing an acoustic tutorial, quite and odd place to find how to activate 2d les model,
Old   May 17, 2005, 05:14
Balaji
hi,
can you tell me what exatly this is.I tried this in comand line .It didn't work.
thank you
balaji
Old   May 17, 2005, 05:47
zxaar
it should work, before posting the message i checked it then only i put it on forum,
further by this command u should eb able to see les models in viscous panel where u enable turbulence, so here when u check that option it calculates les model
Old   May 17, 2005, 06:43
  #11
Balaji
hi,
I don't know how to use this command.I put this in the command line. It came Invalid command[rpsetvar].
Thank you.
Old   May 17, 2005, 07:03
  #12
zxaar
which version of fluent u r using, and make sure that you are in 2d version of fluent (i have checked this fluent 6.1. and 6.2, and it worked fine)
Old   May 18, 2005, 12:11
  #13
Balaji
I am using fluent 6.1 and 2d version. If Possible please send me a tutorial which explains about this command.It will be useful for me. Sorry for taking your time.
Thank you
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 22:55
Two-equation turbulent models: low re airfoils truffaldino Main CFD Forum 51 March 19, 2012 18:57
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 21:31
Different turbulent models for the same material John Siemens 1 May 2, 2007 03:25
Laminar vs. Turbulent Models Dahvid Brown FLUENT 3 October 23, 2000 02:36
