Hi! Is it possible to import a file created by Proeng in Gambit? if it is, how can I do? thanks a lot!
You can buy the Pro/E native import module from Fluent. But I think it's more of a pain than its worth. It only imports virtual geometry, which is a huge problem.
I recommend saving a step file from Pro/E. (File->Save a Copy, and change the file format to Step). Then you can import it into Gambit. Hope this helps, and good luck, Jason |
Well my dear the best way to import a file in gambit is the STEP file if your model is in 3dimension and for 2d use IGES FORMAT.
Gambit Import error | GUEST | FLUENT | 7 | May 30, 2019 11:46 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 14:21 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
How to Import 3D objects from Pro-Engineer to Gambit? | Tomb | FLUENT | 3 | July 5, 2000 12:12 |
Autocad import into Gambit | Paul | Main CFD Forum | 5 | July 12, 1999 04:19 |
