mass flow rate error
Old   May 22, 2005, 00:32
Default mass flow rate error
Masood
hi at a certain flow x-sec area when i enter velocity at that area and using water as fluid . when i check mass flow rate from "fluent report" menu it reprts wrong mass flow rate. the x-sec area is correct. but why there is error in mass flow rate. and if i enter mass flow rate velocity is too high reported by fluent then actually. whts happening.
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 05:55
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
