June 14, 2005, 14:48 |
LES concentric annulus
Hi. I'm trying to LES a concentric annulus flow using periodic BC. Actually, I'm talking about two pairs of periodic BC faces (don't want to mesh the whole 360). One in the flow direction (X)-parallel to the axis and the other on the sides of say 30 degrees sector which should be at 30 one to the other. Is there going to be a problem in Fluent? I.e. will it be enough to define flow in X direction in the periodic BC and it will be equal velocities etc. at the second pair of faces? Thank you.
Single annulus concentric cylinder | Satya prakash | Main CFD Forum | 0 | February 3, 2011 00:40 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Problem with Eccentric pipe annulus..Pls Help me | Parag Ramteke | FLUENT | 2 | April 4, 2005 06:34 |
Turbulent concentric annulus | JonS | Main CFD Forum | 3 | August 10, 2004 07:02 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
