Error while reading mesh file
Old   July 21, 2005, 22:26
Default Error while reading mesh file
sak
Hi Fluent Users
iam getting an error while reading the mesh file, its a 3d geometry and the error its says is " skipping zone inlet_outlet_shadow (not referenced by grid)".
here the inlet and outlet is periodic. any suggestion is appreciated. thanks in advanced
regards
sak
Old   July 22, 2005, 03:48
Default Re: Error while reading mesh file
Sham
UDF could help I think.
Sham.
Old   July 22, 2005, 20:45
sharuk
even i'm getting the same error, is it really a error, or we can skip this. i'm solving periodic rotational flow
Old   July 25, 2005, 08:28
Jason
inlet_outlet is your periodic zone... inlet_outlet_shadow is a "shadow zone", which is basically a copy of inlet_outlet used to compute values across a periodic zone. It's not a problem. If Fluent requires another shadow zone, then it will create it.
Jason
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
wrong dimensions when reading mesh file stella FLUENT 3 October 12, 2005 12:30
