change temperature unit
Old   August 1, 2005, 11:30
Default change temperature unit
suti
Could someone please tell me if I could change the temperature unit, i.e. from Kelvin to Celsius degree, that is displayed on the color map of the temperature contour.
Thanks
Old   August 1, 2005, 14:28
Default Re: change temperature unit
Jason
Define -> Units
Scroll down under "Quantities" until you find temperature and select the units you want to use under "Units"
Good luck, Jason
Old   August 1, 2005, 16:19
suti
thank you, jason
Old   August 2, 2005, 07:59
suti
Jason, do you know if I can change number format (default is in exponential form) or even unit of time (default is in second) displayed (when running unsteady case) on pictures generated by Fluent. For example, if you create a picture of static temperature contours at 5 minutes or 300 seconds, Fluent will show "(Time=3.0000e+02)" next to contours of static temperature at the bottom of the picture.
thank you.
Old   August 2, 2005, 08:40
Jason
I know you can change the number format on the colorbar by going to Display->Colormap and changing from exponential to float.
As for the time in the annotation of the picture... I'm not sure how to change that. One thing you can do is Display->Annotate and if you click on the time you can edit it. It's a bit awkward... I've had better luck clicking and holding because a cursur shows up when you do that and lets you know what you're editing. I would think there's a better way, but I don't know of any.
Hope this helps, and good luck, Jason
Old   August 3, 2005, 00:06
suti
thank you, jason
Conjugate heat transfer: coupled wall temperature Sarah FLUENT 7 August 12, 2013 22:36
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
Temperature went outside of its upper limit Atit Koonsrisuk CFX 0 January 8, 2004 11:43
