coal combustion
Old   August 7, 2005, 12:30
Default coal combustion
kchen
Hi, Fluent experts,
Can anyone kindly tell me if Fluent can simulate coal combustion using a model beside the discret phase model? I need to simulate a case in which the coal loading is very high (25% vol). Thanks.
kchen
Old   August 8, 2005, 06:22
Default Re: coal combustion
HP
Hi kchen! I don't have a complete answer to your question and I would be happy if any coal-combustion expert will provide us his knowledge.
I know for sure that you will have to use the Eulerian - Eulerian approach and not the Euler-Lagrange (DPM), due to the high particle loading. I think that with version 6.2, which can incorporate heterogeneous reactions and mass transfer between phases you will be able to solve your problem. But you will probably have to write some UDFs! What is your case exactly?
Ilias
Old   August 8, 2005, 14:18
kchen
Thanks, HP. I know in the Eulerian model, Fluent can simulate CHAR combustion, but it seems to me that it can NOT simulate coal devolatilization. My case is prety simple, in fact. There are 2 streams: one is carrier gas + coal, and the other is hot air. These two streams mix in a chamber.
Old   August 9, 2005, 02:58
HP
In the following paper drying, devolatilization and char combustion are described in an Eulerian (unified) fashion. But am not sure how can you implement these in Fluent. It is one of the things that I have in mind to try in the future (the E-E combustion). So I would appreciated if you kept me notified about your success or not in this case (and if paper helped you at all!).
The paper is:
"Numerical studies of pulverized coal combustion in a tubular coal combustor with slanted oxygen jet", Guo, Chan, Lau - FUEL
Regards,
Ilias
Old   August 9, 2005, 10:42
kchen
Hi Ilias,
I know in CFX both the E-L and E-E models can be used to simulate coal combustion. But in Fluent, only the E-L model can be used. I will see if I can use UDF to get rid of high solid loading problems.
Old   August 10, 2005, 03:10
HP
Even if you try to model your case with E-L (although your volume fraction of the dispersed phase is greater than 10% and it is not valid), it is sure that you will have convergence problems due to the high mass loading (>>1!). So I think that E-E is your only choice.
Now concerning drying and devolatilization, why can't you just consider them as reactions? (did you see the paper I send you?)
Ilias
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
