August 13, 2005, 11:32 |
Display of Density
Hi, I get the display of density as checker board (like distorted pixel image)...without any variation in the value. I am not using ideal gas.. What can be the reason? Regards
August 14, 2005, 07:24 |
Re: Display of Density
if you look athe schale, you will probably see that the minimum and the maximum are the same. My guess is that you are looking at a uniform density field.
suggestions: change the scale as such that min and max are at least slightly different. Do you see the constant density field? If so, and if you think density variations in your flow problem are important: do not use a constant density material. Laika, still orbiting |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
Variable Density Function | ryzd | FLUENT | 1 | August 25, 2011 14:16 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
variable density water | Atit Koonsrisuk | CFX | 2 | July 24, 2003 03:07 |
