Internal/interior Boudaries with GAMBIT
Like Tree1Likes
  • 1 Post By Jason
Old   August 22, 2005, 10:09
Default Internal/interior Boudaries with GAMBIT
pk
I am trying to simulate a 3d flow around a 2 cylinders in a cross shaped.Both of them are in a Control Flow volume .
I have define with GAMBIT - the boundaries of my Control Flow volume as WALL (4 faces of a brick ) - One INLET VELOCITY (one face of my Control Flow volume) - one PREssure OUTLET (the last face of my control FLow volume).
My 2 cylinders are define as Internal Or Interior, but in both case I got this error msg , when I read the case in FLUENT:
"Cannot change interior.3 to interior because there is only one adjacent cell thread ".
What does it means ? Any clue ?
Thanks for any help
Old   August 22, 2005, 11:11
Default Re: Internal/interior Boudaries with GAMBIT
Jason
That's because they're not interior BC's. An interior BC allows fluid to pass through it without any interference (these are good for post-processing, or if you want to switch this surface to another BC later on, like a Pressure-Jump or a Wall, but that's it).
What you're trying to do is specify the cylinders as Walls. This way the flow can't pass through the BC and will be diverted around it.
Another way of looking at it...
An Interior BC is an imaginary plane you can use to look at or calculate flow properties, while a Wall BC is the equivalent to a hard surface which doesn't allow flow to pass through it.
Good luck, Jason
hoga likes this.
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 01:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
