Please help with liquid fuel combustion modelling
Like Tree2Likes
  • 1 Post By MANOJ KUMAR
Old   August 27, 2005, 22:10
Default Please help with liquid fuel combustion modelling
tom
I am new for combustion simulation. In Fluent tutorial, there is an example "Modeling Evaporating Liquid Spray". I want to developed it to a combustion. Yes, I want to see the combustion. I am using liquid fuel Ch3OH as in the example. After I set the problem as the example, I am using PDF method as in the coal combustion tutorial example. I followed the prePDF method in the tutorial. After 1000 iteration, it does not burn at all. Can anybody helps?
I would like to know (1) Does my PDF file have problem? Who can give me a pdf for other fuel so I can continue the example? (2) Should I use other method than PDF method? (3) If PDF can, what problem could I have?
Thank you. drop me a mail if you can: tomzijizhang@+@yahoo.se (I use @+@ to prevent email robot. Pls take out +@ when you send me mail).
Old   August 29, 2005, 02:38
Default Re: Please help with liquid fuel combustion modell
K. Jagus
Did you ignite the mixture?
Old   August 29, 2005, 02:39
K. Jagus
Also, do You use DPM Model for particle injection? If so, make sure you have droplet set under particle type in injections panel, default inert particle does not burn.
Old   September 3, 2005, 03:57
MANOJ KUMAR
You do the problem like combustion given in Fluent solver same problem i taken and get answer give me full detail of u problem means 2d OR 3d
Hayder Mohammed likes this.
Old   October 17, 2014, 21:08
amin
aminbayat is on a distinguished road
you need to define a high temperature path.
aminbayat is offline   Reply With Quote
Modeling of artificial composite liquid fuel combustion Olga FLUENT 0 June 14, 2011 23:09
Combustion modelling of dual fuel engine ?? ashishashish_5 FLUENT 1 January 18, 2010 20:42
Help! Warnings on liquid fuel combustion Julie Siemens 0 August 31, 2004 10:58
combustion chamber for liquid fuel Kirill CFX 1 November 18, 2002 10:07
Liquid fuel combustion Yong-Ju Hong FLUENT 3 May 17, 2000 04:27
