Surface tension options for VOF models
Old   September 14, 2005, 03:39
Default Surface tension options for VOF models
chapelle
Does anybody know where I could access the surface tension options of the VOF model through the text commands.
The path 'solve/set/surface-tension' given in fluent documentaion does not exist and I could not find those options anywhere.
Moreover, I would like to know about experiences in using those options.
Thanks, Pierre
Old   September 14, 2005, 09:21
Default Re: Surface tension options for VOF models
edi
What about define/phases/interaction-domain?
You can access surface tension options also via GUI scrolling down define/phases and then clicking on "interaction".
I personally used this option (together with wall adhesion) in an preliminary study on fluid behaviour in microgravity. I know that in ZARM institute (Bremen) they used fluent in 2001 to model such phenomena. I think they also validated a test case but not sure.
Cheers
Edi.
Old   September 14, 2005, 11:14
chapelle
thanks for your reply
Actually, I was refering to "hiden" surface tension options that are mentionned in 24.2.8 of Fluent documentation. I explored most of the menus of the interface, but coud not find them.
Old   September 20, 2005, 03:40
edi
Ok, now I got it. Sorry for the delay, I was busy. To tell you the truth, I found out the solve>set>surface-tension options in the TUI without any problem...even without enabling the VOF multiphase model nor inputing the surface tension value in the phases>inteeraction panel... . Are you sure you're working with fluent 6.2? In 6.1 version those options are not available...
Cheers
Edi.
Old   September 20, 2005, 03:49
chapelle
Thanks.
Effectively, I am working with version 6.1.22. I should have think of it !!!
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
Surface tension gradient - Marangoni stress- through UDF marimuthusundar FLUENT 0 October 11, 2010 09:07
Inconstant Surface Tension on Interface in VOF Atieh FLUENT 0 February 9, 2007 02:37
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
VOF SURFACE TENSION EFFECTS ozgur FLUENT 0 March 26, 2004 03:36
