I am simulating a thin liquid film on a pipe wall which travels at a much lower velocity than the gas phase. The liquid film moves at a velocity of about 0.1 m/s. The gas phase moves at a velocity of 6 m/s. Is this possible when using the VOF model? Also, the liquid volume fraction is about 6% at the pipe inlet.
Thank you. |
hi
no u cannot give two velocities but instead u can give the volume fraction of the phases. thanks Rashmi |
Thank you for your reply Rashmi,
Yes, but I have been able to specify two different inlet velocities by have separate inlets for each phase. However, when the difference between the two velocities is too great the VOF model tends to mix the two phases together. The liquid and gas phases should have a clear defined boundary layer between them. So this is why I am curious to know if the VOF model is suitable when modeling two phases moving at differing velocities. Thanks. Regards, John. |
VOF Inlet condition | Rizwan | FLUENT | 15 | July 5, 2018 16:33 |
ATTENTION!! Validty of Fluent's VOF?? | ozgur | Main CFD Forum | 3 | February 18, 2004 18:19 |
ATTENTION!! Validty of Fluent's VOF?? | ozgur | FLUENT | 1 | February 18, 2004 11:59 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
about VOF model | rey | FLUENT | 5 | August 13, 2002 06:02 |
