User defined scalar boundary condition
Old   September 19, 2005, 04:09
Default User defined scalar boundary condition
Philip
I have a problem regarding the inlet boundary condition of my scalar. I have an inlet with a periodic velocity, where the velocity first is positive, then negative. While the inlet velocity is positive the scalar has the value 1, but then when the inlet velocity is negative the scalar was first set to 0. It then showed that it is not possible for the scalar to flow back. My idea was then to change the inlet scalar boundary condition to flux during the backward flow phase.
There seems, however, not possible to change from specified value to specified flux during computation, or does anyone know how this can be solved?
Regards: Philip
Old   December 4, 2013, 10:23
David Russ
mlbontbs87 is on a distinguished road
I know this was from 8 years ago, but did you ever find a solution to this?
mlbontbs87 is offline   Reply With Quote
UDF to modify the value of a user defined scalar Raja Banerjee Fluent UDF and Scheme Programming 5 March 5, 2019 14:19
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Boundary condition vector field gradient from two sides of patch face quba OpenFOAM 0 December 12, 2007 05:26
User defined scalar Tomik FLUENT 0 February 8, 2007 19:23
