convergence in fluent!!!
Old   October 11, 2005, 22:29
Default convergence in fluent!!!
Rashmi
hi all
i just wanted to know that is it necessary for any simulation to converge the iterations.....
thanks Rashmi
Old   October 11, 2005, 22:38
Default Re: convergence in fluent!!!
KP
Yes. otherwise you will not acheive a numerical solution. On top of it I would advise to look for grid independence too....monitor the variable you are looking for.. CFD without a converged and grid indeoendent solution does not make much sense. Good luck in your runs.
Old   October 11, 2005, 22:47
Rashmi
hi
thanks for response.i have already run my simulation for 1000 iterations so do i increase them till i get the converged solution
thanks Rashmi
Old   October 12, 2005, 00:17
Riaan
Typically, yes, keep itterating till you reach "convergence". There is no magic number, but residuals in the 10e-6 range should give reasonable values.
In one case I am running, even though my residuals are all down in the 1e-6 range, a parameter that I am tracking (mass-flow throught a duct) is still changing, and hence the solution is not converged.
Old   October 12, 2005, 00:43
Matt
Obviously, what happens is some times your paramters look like they have converged, however after some hundred iterations they start to diverge or converge! Well, patience is the key here and keep iterating untill your parameter is flat.
Thanks,
Matt
Old   October 12, 2005, 12:43
Lam
i do agree with kp that a case without convergent and grid independent is not make sense.
we always need a STABLE solution.
my way to check the convergency is to monitor volocity or pressure changes at few points in the critical regions.
i always put the residual range where the case will never acheive.
once the velocity or pressure at those points are not changing.
that means your case is converged.
grid independence is to make sure the grid size won't influence the final predictions.
Old   October 13, 2005, 00:41
Rashmi
thanx iam new to the fluent...yes i agree but how do u select the points..or monitor the velocity or pressure...plz guide
Old   October 13, 2005, 09:14
Lam
how to select the points? common sense. select the points in the high gradient region where will change rapidly. if even that kind of region being stable, no reason other regions are not stable.
monitor velocity or pressure? Depend on what flow properties you want to investigate. If your project focus on velocity prediction, then monitoring velocity. If pressure or temperature, then monitoring pressure or temperature. Just monitor the flow properties which are important to you.
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 13:31
convergence problem with FLUENT cavitation model Belete Kiflie FLUENT 3 February 20, 2006 10:16
Standard convergence limit in FLUENT 6.1 Henrik Ström FLUENT 3 December 20, 2005 08:48
CONVERGENCE IN FLUENT Fer Main CFD Forum 6 November 17, 2005 02:34
