Rotating Tire
Old   October 20, 2005, 11:22
Default Rotating Tire
James
Dear All,
I was wondering if any one can help me with a small question I have here.
I want to model a tire thats rolling on a ground at a speed of 100 Kph. Actually the tire is attached to the car and obvioiusly the ground would be moving as well while the car is moving.
I would be grateful if any one can suggest a way on how to model it? Any special meshing considerations? etc.
Thanks a lot in advance.
James
Old   October 21, 2005, 12:45
Default Re: Rotating Tire
Rajat
Hi James , you can move the tire by going into the boundary conditions panel and defining the tires to rotate at certain radians/sec. obviously the tires would also rotate at 100 kph. just convert that into rad/sec. Just be careful that tire rotates in the opposite direction with respect to the road. No need to mess around with the mesh.
Have fun Rajat
Old   October 21, 2005, 15:58
James
Hi Rajat,
Thanks a lot for the advice. I guess we have to define the rotation axis as well. I thought it would be a moving mesh example!
Thanks once again.
James
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
Dynamic mesh in Fluent to study tire in contact with road surface lihuang FLUENT 10 March 8, 2011 10:21
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 08:25
