October 20, 2005, 11:22 |
Rotating Tire
Dear All,
I was wondering if any one can help me with a small question I have here. I want to model a tire thats rolling on a ground at a speed of 100 Kph. Actually the tire is attached to the car and obvioiusly the ground would be moving as well while the car is moving. I would be grateful if any one can suggest a way on how to model it? Any special meshing considerations? etc. Thanks a lot in advance. James |
October 21, 2005, 12:45 |
Re: Rotating Tire
Hi James , you can move the tire by going into the boundary conditions panel and defining the tires to rotate at certain radians/sec. obviously the tires would also rotate at 100 kph. just convert that into rad/sec. Just be careful that tire rotates in the opposite direction with respect to the road. No need to mess around with the mesh.
Have fun Rajat |
October 21, 2005, 15:58 |
Re: Rotating Tire
Hi Rajat,
Thanks a lot for the advice. I guess we have to define the rotation axis as well. I thought it would be a moving mesh example! Thanks once again. James |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
Dynamic mesh in Fluent to study tire in contact with road surface | lihuang | FLUENT | 10 | March 8, 2011 10:21 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
IcoDyMFoam how to define more than one rotating regions | naoko_oyama | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 08:25 |
