Centrifugal impeller modelling
Old   October 25, 2005, 09:54
Default Centrifugal impeller modelling
Rik
Has anybody got any experience with meshing a centrifugal impeller in 3D? i've heard that meshing the 3D model can be tricky and that it's best to mesh 2D and then project it mesh linked.
any helpful hints????
Old   October 27, 2005, 06:43
Default Re: Centrifugal impeller modelling
gisu park
hi i am working on the centrifugal impeller. At this stage, i am working on meshing volume I actually modelled goemetry in solidworks2004 and imported file in gambit as IGS file. Then i created a virtual volume in gambit. And then i run in fluent. Due to complexity of shape of impeller, i think its quite hard to model in gambit unless you use turbo option. Hoe this helps.
[ICEM] Meshing Centrifugal Impeller Bellmo ANSYS Meshing & Geometry 8 November 27, 2018 13:02
Centrifugal Pump Impeller design invincible328 Main CFD Forum 27 September 21, 2014 10:59
[ICEM] Meshing a centrifugal compressor impeller Mitpostdoc ANSYS Meshing & Geometry 8 February 25, 2011 10:51
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 03:07
Centrifugal fan modelling GU FLUENT 0 December 20, 2005 08:37
