November 3, 2005, 04:42 |
sensitivity analysis
Hello everyone! My Fluent base-case dealing with coal combustion has reached convergence. Now I would like to make sensitivity analysis: I have to vary the primary air flow rate in order to analyse the effect on combustion process. I don't know if I have to reinitialise the solution every time I change the mass flow rate or if I can start the calculation from my base case. Thanks for your help! By Silvia
November 3, 2005, 04:48 |
Re: sensitivity analysis
If your boundary conditions dont vary too much its always a good idea to use an existing solution as starting point for a new calculation. Change the air mass flow rate an continue the calculation.
RoM |
Sensitivity Analysis - Grids Not Asymptotic | Marc | FLUENT | 2 | November 8, 2017 06:35 |
CFX Ansys convergence(RMS or Max Residual) | farianka | CFX | 5 | November 21, 2010 05:25 |
Grid sensitivity analysis | darookie | CFX | 2 | August 25, 2009 09:00 |
What exactly is a sensitivity analysis? | Josh | CFX | 3 | August 19, 2009 09:18 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 17:46 |
