Import gambit file in Tgrid
Old   November 22, 2005, 18:49
Default Import gambit file in Tgrid
Elizabeth
It's possible to import a Gambit file .dbs without mesh in Tgrid? If yes what I have to do? thank you very much to everyone Elizabeth
Old   December 1, 2005, 10:09
Default Re: Import gambit file in Tgrid
Bob
I don't know if it is possible without any mesh. But you can export a surface mesh from gambit into Tgrid format and then import it to Tgrid. As I think you can remesh that surface mesh in Tgrid.
Old   December 1, 2005, 10:30
Elizabeth
Thank you Bob for your answer. I will try to export a surface mesh from Gambit and remesh it in Tgrid.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
