Radiation in combustive case
Old   November 25, 2005, 08:09
Default Radiation in combustive case
Silvia
Hello! I would like to know if someone had the same problem I had to face modelling solid fuel combustion... I realized that radiation model with P1 gives good results only if a specified boundary condition at the furnace wall is set, such as a constant temperature. If I set the heat flux through the walls the case doesn't reach convergence and p1 residuals grow more and more...Furthermore, combustion is not complete. Has someone faced the same problem with radiation? Thanks Bye
Old   November 26, 2005, 06:14
Default Re: Radiation in combustive case
kiran
hi silvia, the same problem i faced.when i tried to give heat flux it is diverging and after some stage it gave me error message. i dont know how to deal with it if you find answer please reply to me thank you kiran
Old   November 28, 2005, 04:28
Silvia
Why don't you set a constant temperature as wall boundary condition instead of the heat flux? Chose the wall temperature in such a way that the wall heat exchange is equal to the known heat flux...BYe
Radiation in UV reactor Ferdinando FLUENT 2 June 4, 2020 07:19
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
