UDF in MDM Tutorial
Old   November 28, 2005, 07:34
Default UDF in MDM Tutorial
mAx
Hi, I have a question about UDF. In the MDM Tutorial, the UDF calculates the piston's motion produced from the drop pressure within the valve. When I take a closer look at the UDF,I don't understand 2 stuffs. * what means F_AREA_CACHE? I understand F_AREA, but ...-CACHE? *in the CG_MOTION(), the pressure force on the piston is calculated, but I don't achieve to recognize if there is any profection for the force calculation. I mean if the piston slides on the x axis, the pressure force has to be computed along the x axis, In the UDF I don't see anything which give the choice for choosing x,y or z axis.
Any Idea Thanks mAx
UDF and text commands David FLUENT 3 June 26, 2022 23:10
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF programming fullmonty FLUENT 5 June 30, 2011 02:40
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 00:04
