Hi, I have a problem with my UDF. It runs well under serial, but not under parallel. And I need to run it under parallel. I paste, the UDF below. Could someone tell me what's wrong? Thank you very much. ******* #include <stdio.h> #include "udf.h"
#if !RP_NODE # define UDF_FILENAME "udf_loc_velo" # define UDF_DATA "data.dat" # define K_SPRING 1605 /*spring constant/2 (N/m)*/ # define m 0.0365 /*mass of piston/2 (kg)*/ # define init_disp 0.008 /*initial displacement of spring (m)*/ /* read current location and velocity from file */ static void read_loc_velo_file (real *loc, real *velo) { FILE *fp = fopen(UDF_FILENAME, "r"); if (fp != NULL) { float read_loc, read_velo; fscanf (fp, "%e %e", &read_loc, &read_velo); fclose (fp); *loc = (real) read_loc; *velo = (real) read_velo; } else { *loc = 0.0; *velo = 0.0; } } /* write current location and velocity in file */ static void write_loc_velo_file (real loc, real velo) { FILE *fp = fopen(UDF_FILENAME, "w"); if (fp != NULL) { fprintf (fp, "%e %e", loc, velo); fclose (fp); } else Message ("\nWarning: cannot write %s file", UDF_FILENAME); } /* write current location and velocity in datafile */ static void write_data_file (real time, real loc, real velo, real force) { FILE *fp = fopen(UDF_DATA, "a+"); fprintf (fp, "%e %e %e %e \n", time, loc, velo, force); fclose (fp); } #endif /* !RP_NODE */ DEFINE_ON_DEMAND(reset_velocity) { #if !RP_NODE real loc, velo; read_loc_velo_file (&loc, &velo); write_loc_velo_file (loc, 0.0); Message ("\nUDF reset_velocity called:"); #endif } DEFINE_CG_MOTION(valve, dt, cg_vel, cg_omega, time, dtime) { #if RP_NODE Thread *t = DT_THREAD (dt); face_t f; #endif real loc,velo,force; /* reset velocities */ NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); if (!Data_Valid_P ()) return; #if RP_NODE /* compute force on piston wall */ force = 0.0; begin_f_loop (f, t) { real *AA; AA = F_AREA_CACHE (f, t); force += F_P (f, t) * AA[2]; } end_f_loop (f, t) #endif #if PARALLEL force = PRF_GRSUM1(force); node_to_host_real_1 (force); #endif # if RP_2D if (rp_axi) force *= 2.0 * M_PI; # endif #if !RP_NODE read_loc_velo_file (&loc, &velo); /* add in spring force */ { real s_force = K_SPRING * (loc + init_disp); force = force - s_force; } /* compute change in velocity */ { real dv = dtime * force / m ; velo += dv; loc += velo * dtime; } Message ("\nUDF valve: time(s)= %f, z_vel(m/s)= %f, force(N)= %f, loc(m)= %f\n", time, velo, force, loc); write_loc_velo_file (loc, velo); write_data_file (time,loc,velo,force); #endif /* !RP_NODE */ #if PARALLEL host_to_node_real_1 (velo); #endif cg_vel[2] = velo; } DEFINE_CG_MOTION(moving_fluid, dt, cg_vel, cg_omega, time, dtime) { #if !RP_NODE Thread *t = DT_THREAD (dt); face_t f; real force, loc; #endif real velo; /* reset velocities */ NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0); if (!Data_Valid_P ()) return; #if !RP_NODE read_loc_velo_file (&loc, &velo); #endif /* !RP_NODE */ #if PARALLEL host_to_node_real_1 (velo); #endif cg_vel[2] = velo; } |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
