How to display dT/dx?
Like Tree3Likes
  • 3 Post By RoM
Old   December 5, 2005, 11:58
Default How to display dT/dx?
Williams
Hello everyone
I want to display dT/dx, dT/dy, and dT/dz in fluent. Could anyone give me some help?
Thanks
Williams
Old   December 6, 2005, 04:48
Default Re: How to display dT/dx?
Pospelov
I think you can do it by command line. You should write: dis, then enter, then con, then enter, then enter to see the contor of what do you want to display. dT/dx -- must be in this list...
Old   December 6, 2005, 05:31
RoM
You will need an UDF to access temperature gradients. The following udf will copy dT/dx into a user defined memory so you can postprocess it. To copy dT/dy change C_T_G(c,t)[0] to C_T_G(c,t)[1] and for dT/dz to C_T_G(c,t)[2]. The udf runs in interpreted mode (define->user-defined->functions->interpreted) but you will have to do some additional things to make it work.
1. Allocate one user defined memory. Define->User-defined->memory, set the number to 1.
2. Force the solver to keep gradient values stored. In TUI tpye //solve/set/experts and answer yes to question "Keep temporary solver memory from being freed?"
3. Run your solution for 2 iterations.
4. Run the udf. Define->user-defined->execute on demand
Good Luck, RoM
#include "udf.h"
DEFINE_ON_DEMAND(store_grad)
Domain* d;
Thread *t;
cell_t c;
d=Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0)=C_T_G(c,t)[0];
end_c_loop(c,t)
mechy, nenazarian and hrmazloumi like this.
Old   December 6, 2005, 09:47
Williams
Thanks a lot.
Old   May 16, 2010, 23:54
Hongjin Wang
sosososo1114 is on a distinguished road
By the way, as the udf manual refers: it seems better to use C_T_RG(c,t) macro than the C_T_Gs. it seems that C_T_G fails to return the accurate value you want at the boundary faces.
have a good day.
sosososo1114 is offline   Reply With Quote
Old   May 17, 2010, 05:08
Josh_Blue is on a distinguished road
Hi Hongjin,
thanks for your comment. Could you please tell me how to use this macro step by step?
Thanks in advance!
Regards
Josh_Blue is offline   Reply With Quote
Old   May 19, 2010, 05:58
Hongjin Wang
Originally Posted by Josh_Blue View Post
Hi Hongjin,
Thanks in advance!
Regards
Hi, Josh,
"As in the case of gradient variables, you can retain all of the reconstruction
gradient data by issuing the text command solve/set/expert and then answering yes
to the question Keep temporary solver memory from being freed?."(says UDF manual)
as Rom mentioned, u should define a udm first, u can use GUI as follow: Define->user defined->memory. You may need three udfs to get the C_T_RG display in counters. The first one is the udm reserve udf, you can copy an example from udf manual at Page 3-46. The second is udm clearance udf. and the example mentioned above also includes this one. The third is quit alike the one Rom provided above. You just need to chang the C_T_G(c,t)[0] in the 12th line to the C_T_RG(c,t)[0].
Have a good day
Old   October 27, 2012, 17:44
Negin Nazarian
nenazarian is on a distinguished road
This thread was really useful for me. I just have few questions:
1. Does (dT/dy, dT/dz...) only gets available after doing these steps?
I only put "C_UDMI(c,t,0)=C_T_RG(c,t)[0];" in my udf which is the gradient in x direction but now I also see other terms (dT/dy, dT/dz) available in my case. Why is that?
2. What is the major difference between RG and G and when to use them?
I know that the value obtained by each of them would be different but Im not sure if I understand how to differentiate them.
3. After doing these steps, there is another variable available in my case :
"user defined memory"
what is that?
I appreciate any help.
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   December 6, 2018, 19:57
Argenis
argenisbnl is on a distinguished road
Originally Posted by sosososo1114 View Post
Hi, Josh,
Have a good day
Hello, I hope it's not too late, I have a question, if I run a number of cases using design points, not doing those steps that were mentioned before will affect my project? I mean, the UDF will not work after first case? Thanks in advance.
argenisbnl is offline   Reply With Quote
problems with Fluent display windows chris FLUENT 3 January 7, 2016 10:44
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
running CFX 11.0 on Fedora 7 : display problems Eric Joubarne CFX 1 October 3, 2007 16:51
free surface display carno Siemens 4 October 7, 2005 01:03
display and roughness nicolas FLUENT 2 July 23, 2002 20:09
