Turbulent slug flow
Old   December 22, 2005, 03:42
Default Turbulent slug flow
Paul_C
Dear All,
Does anyone has any idea which turbulent model i should use for slug flow in a channel?
Any advice will be appreciated.
Thanks in advance
Old   December 25, 2005, 03:07
Default Re: Turbulent slug flow
nasser
use VOF Model
Old   December 26, 2005, 03:47
Paul_C
Thanks for your reply.
Is there any article regarding when the slug flow will be turbulent or laminar? If it is turbulent, what are the suitable models?
the flow considered here is through a mini channel of 2x2mm with a Re of about 10.
Thanks in advance
Old   December 27, 2005, 20:24
Chetan Kadakia
Define slug flow...
Re = 10 is pretty low. Use the laminar model.
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
slug flow simulation mvee FLUENT 5 August 9, 2012 08:05
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
Reynolds and Turbulent Flow Frederic Dubinski Main CFD Forum 2 October 20, 2004 13:57
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
