February 11, 2006, 06:53 |
Dynamic mesh
Hello to all,
I have a problem: I'm using the dynamic mesh technique with a profile; when I say to Fluent to iterate, the following message appears me: WARNING: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: () what means? someone can help me? Thanks |
February 11, 2006, 07:12 |
Re: Dynamic mesh
How did you generate your mesh?
Did you use Gambit? or a third party mesher? |
February 11, 2006, 07:19 |
Re: Dynamic mesh
Ciao Giuseppe, are you running an unsteady analysis, right? Unfortuantely Fluent dynamic mesh algorithm is not very robust. Try lowering time-step and raising spring-iteration. Luca
February 11, 2006, 08:30 |
Re: Dynamic mesh
To Alan,
I have generate a quad map grid with Gambit. Thanks for reply |
February 11, 2006, 09:17 |
Re: Dynamic mesh
Amico Giuseppe, Did you get it to work? I've run into that problem too. I know it's painful. What I found is that you need to move the boundary in steps that are shorter than the distance between 2 nodes, try half of the distance between 2 nodes. Let me know what you found. Ciao ragazzo Javier
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Incylinder dynamic mesh with volumetric reaction | mas | FLUENT | 4 | May 3, 2012 10:22 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
