Dynamic mesh
Old   February 11, 2006, 06:53
Default Dynamic mesh
Giuseppe
Hello to all,
I have a problem: I'm using the dynamic mesh technique with a profile; when I say to Fluent to iterate, the following message appears me:
WARNING: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: ()
what means? someone can help me? Thanks
Old   February 11, 2006, 07:12
Default Re: Dynamic mesh
Alan
How did you generate your mesh?
Did you use Gambit? or a third party mesher?
Old   February 11, 2006, 07:19
Luca
Ciao Giuseppe, are you running an unsteady analysis, right? Unfortuantely Fluent dynamic mesh algorithm is not very robust. Try lowering time-step and raising spring-iteration. Luca
Old   February 11, 2006, 08:30
Giuseppe
To Alan,
I have generate a quad map grid with Gambit.
Thanks for reply
Old   February 11, 2006, 09:17
Javier
Amico Giuseppe, Did you get it to work? I've run into that problem too. I know it's painful. What I found is that you need to move the boundary in steps that are shorter than the distance between 2 nodes, try half of the distance between 2 nodes. Let me know what you found. Ciao ragazzo Javier
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
