February 15, 2006, 23:40 |
Wall boundary condition (heat transfer)
Hello everyone
I have faced some problems about setting the Wall Boundary Condition. In my problem, I would like to set up a wall boundary which it's surface temperature, heat flux and convective coefficient are not constant and are affected by the surrounding environment. For instance, the temperature, heat flux and convective coefficient would be affected by the temperature of the fluid, the radiantion from other walls, etc. However, I don't know how to set up a wall like this in fluent. Would anyone can help me to solve this problem? Thank you very much! |
February 16, 2006, 04:42 |
Re: Wall boundary condition (heat transfer)
hi Arnold
I feel u need to use user defined functions udfs for the case you are considering Please go through the udf manual of FLUENT if you are using FLUENT They will be similar to C codes bye Ravi Kiran |
February 16, 2006, 12:51 |
Create the wall. Set the BC to coupled.
February 16, 2006, 22:33 |
Thank you very much for your help!
February 16, 2006, 22:35 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
How to set the Heat Flux boundary condition at Outlet | creddy_trddc | CFX | 3 | September 21, 2011 07:44 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Boundary Condition for Heat Transfer | wilko | OpenFOAM Running, Solving & CFD | 0 | October 12, 2009 17:58 |
boundary condition for Heat Transfer | sylvain | Main CFD Forum | 4 | June 30, 2005 15:26 |
