continuity residual
Old   February 25, 2006, 06:06
Default continuity residual
majesticcc
Hi!ı am trying to solve a laminar flow in the neighbourhood of a disk rotating in fluid at rest.I am using 2d axisymetric swirl solver and laminar model.angular velocity of disk is 0.5 rad/s.But residuals of contunity did not decrease enough ı can not find the reason is there any body have an idea about this problem?
Old   February 25, 2006, 06:35
Default Re: continuity residual
Thomas
Are u sure this is a laminar problem? try to use the k-e; it will give good results also if the problem is really laminar. How's your mesh on the boundary?
Old   February 25, 2006, 07:05
majesticcc
ı tried different kinds of mesh but the solution is same.also ı used 2d and 2ddp.now a ı am using uniform mesh.Pressure inlet-pressure outlet-wall-axis are my boundary conditions.
Old   February 26, 2006, 02:31
Kharicha
Verify that you have enough points within your Ekmann layer...at least 10....
use presto, and use high underrelaxation factor for the pressure and low for the velocity...
Old   February 26, 2006, 23:00
rener
sdfa
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
