Errors while eporting mesh to Fluent
Old   February 28, 2006, 18:59
Default Errors while eporting mesh to Fluent
Vidya Raja
I have ameshed geometry in Gambit. I used the sizing function to mesh the whole volume, thus ignoring the heirarchy (i.e., mesh edges, faces, volume). For this, I specified 2 faces (these are symmetrical)to be the source faces. But when I tried to export the entire meshed geometry it did not export these edges and a few others and gave an error which said that these edges are not meshed and so could not be exported.
I do not understand why this happens and especially because I used the sizing function for the entire volume. Can someone help me with this?
Thanks, Vidya
Old   March 1, 2006, 00:17
Default Re: Errors while eporting mesh to Fluent
mAx
try to connect all faces, and also the edges.
Old   March 1, 2006, 04:35
fred
make sure that all the real vertices are connected. you can do so by zooming to the most possible extent.
Regards
Old   March 1, 2006, 14:20
Vidya Raja
I tried to connect the faces, but it displays a warning saying:
The call to cnnect resulted in no actual opeartions.
Now how do I solve this problem? Please help.
Thanks, Vidya
Old   March 1, 2006, 18:08
Vidya Raja
Hi mAx and Fred,
The faces and edges that were not exported cannot be connected to each other. So I left them as distinct entities. Is this the reason that they are not being exported? So is there anything that I can do about it?
Thanks, Vidya
Old   March 2, 2006, 00:17
mAx
take care in the connect options: if you juste have real entities, then select real. If not select virtual (and ALL)
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
