March 14, 2006, 08:52 |
Residual logging
Hi everybody!
I am doing long, unattended, unsteady simulation runs and I would like to save the value of all residuals at the end of each time step to an external file for post-processing. Does anybody know how this can be done? /Henrik |
March 14, 2006, 09:04 |
Re: Residual logging
hmmm.... Maybe it can help you if you create an outpu file. start fluent in a background and ask for an output file
> fluent 3d -g -i start.jou >&output.out& at the and of the calculations, you will have all what fluent used to print on screen ou the output file. It is after taht a little bit fastidious to obtain what you will, but it is an option hope it helps |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
