combustion in a furnace
Old   March 30, 2006, 10:41
Default combustion in a furnace
Mattia Bosc
Hi, i have to model a 3d combustion in a furnace. There are 2 streams: one is fuel ( 80% CO, 20% CH4); the other is air. Should i use finite rate chemistry or non premixed combustion? Any suggestions? Thanks
Old   March 31, 2006, 10:21
Default Re: combustion in a furnace
Thomas
With no doubt the use of a pdf table is much more close-to-real than the use of the finite-rate combined with the eddy dissipation model. The use of the pdf table results in a longer flame due to the radicals' reactions, and this could be very important in furnaces' analyses.
Old   March 31, 2006, 14:39
Allan Walsh
Your question is a little like "I want to buy a new car - should I buy a red one or a blue one?" It depends.
What are you interested in? Temperatures? Flow patterns? Emissions? Do you have good data for kinetic expressions if you want to use finite rate chemistry? Do you have experimental data you want to match? How big is the furnace? How will you model turbulence? Will you do a steady-state model?
Contrary to Thomas' answer, you can radicals in finite rate formulation.
Good Luck.
Old   April 1, 2006, 15:07
Mattia Bosc
Thanks for the answers. The combustion chamber is about 67 m3; the mesh is made up of 1600000 elements. i use standard k-e model for turbulence. My targets are temperature and velocity at the exit of chamber ( here i have experimental data to match).
Old   September 29, 2009, 13:22
Robi
robiroy is on a distinguished road
Originally Posted by Mattia Bosc
;130874
Mattia,
Did you get a chance to simulate the combustion in a furnace? I am also working in the same field. I would apprecite if you could help me on the simulation approach.
Thanks,
Robi
robiroy is offline   Reply With Quote
Combustion in a furnace robiroy FLUENT 0 September 29, 2009 13:13
Coal combustion in tangential furnace Jarek CFX 9 November 12, 2007 09:50
Re: Coal combustion in tangential furnace DG CFX 0 November 3, 2007 02:03
Furnace Combustion wall problem Leigh FLUENT 2 December 11, 2006 15:01
Combustion gas temperature in oil-fired furnace HasriL FLUENT 1 July 1, 2005 10:13
