The variable at the edge of boundary layer
Like Tree1Likes
  • 1 Post By maximus
Old   April 7, 2006, 23:22
Default The variable at the edge of boundary layer
maximus
hi,there. I am trying to compute the flow and heat transfer around a cylinder by FLUENT. I want to get the variable at the edge of boundary layer such as the temperature,velocity. But I can't find the method to report these values. Is there the option in Fluent to report this. or must I use the UDF to get these varibles? Also,I want to know if the referece values in the Report panel can be changed. I want to use the value at the edge of boundary layer as referece values, and that's not a single value, but varying with the position. I wonder if anybody has this kind of experience. And I'll appreciate any response. Thanks a lot!!
Maximus
somia baali likes this.
Old   November 30, 2020, 14:25
physics baali
somia baali is on a distinguished road
i have the same your problem to determine Nu number. after this time have you any solution please
somia baali is offline   Reply With Quote
[snappyHexMesh] bad trailing edge boundary layer with snappyHexMesh draufunddran OpenFOAM Meshing & Mesh Conversion 14 March 1, 2018 09:42
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 06:57
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
