I have a number of 2D cases where I can't display filled contours. Instead I just get the grid with colour gradients imposed on the lines. I have seen this message befor, although have had no joy with disabling hardware acceleration as was recommended. Any suggestions. Thanks David |
while plotting don't select any boudary entities in the list, just press plot button.
Genius! Thank you.
David |
Morteza Eslamian
Rep Power: 14 ![]() |
I have the same problem, i.e. in 2D I cannot show the filled contours instead I get grids. I did not undrestand the answer.
It is in the contour section not plot. Any suggestions? I am stuck. Thanks Morteza |
#5 | |
Syavash Asgari
Rep Power: 18 ![]() |
Be sure that no boundaries in the "Surfaces" list be selected in Contour window. Bests. |
Morteza Eslamian
Thanks Syavash. I got it. It worked as you suggested.
SANDRA BENVENUTO
Can you help me?
I can not write Cd multi line when I run parallell and chose time "transient". It's show ""Drag Convergence" "Flow Time" "Cd" 3.87500e-02 1.61505e+03 " when I chose time"steady" "Drag Convergence" "Flow Time" "Cd" 1.00000e-02 1.09653e+02 2.00000e-02 -5.27841e+00 3.00000e-02 -4.84571e+01 4.00000e-02 -6.28311e+01 5.00000e-02 -1.34413e+02 6.00000e-02 -2.63939e+02 " I need to write in Cd file same steady. Thank you. |
Hari Charan
Rep Power: 0 ![]() |
Thanks very much Chandrakanth. It worked
#9 |
Jing
Hi, syavash, I have the same question that the 2D contour can't be shown, while I just got the grid. I am pretty sure that no boundaries in the "Surfaces"
list be selected in Contour window. Can you help me? Thank you very much. |
#10 | |
Syavash Asgari
Can you post a picture of what you get from Contour panel?! |
#11 |
Hells Blade
Rep Power: 8 ![]() |
I am also facing the same problem did any one figure it out what was wrong ?
#12 |
Rep Power: 9 ![]() |
Yes, I faced the same problem. I could not see filled mesh after selected 'Face' option. And as result, I cannot see filled contours after running. Any one could give me a hint to resolve this problem? Because it did not have problem at teh beginning.
Thanks in advance. |
zooming the pressure filled contours | taran | FLUENT | 2 | July 10, 2007 17:42 |
Black spots in filled contours | Phil | FLUENT | 8 | December 12, 2006 13:07 |
how to display contours in unsteady.......... | sandra | FLUENT | 4 | June 6, 2006 08:16 |
display contours every time | linda | FLUENT | 1 | May 28, 2006 21:17 |
display filled contour of temperature gradient | Frederik | FLUENT | 4 | August 23, 2005 05:42 |
